Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - ZX3 ,, sudden drop in gas mileage ??
Old 01-02-2013, 05:44 PM   #14
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 14,454, Level 78
Points: 14,454, Level: 78 Points: 14,454, Level: 78 Points: 14,454, Level: 78
Level Up 1% Completed
Level up: 1% Level up: 1% Level up: 1%
Forum Activity 99%
FF Reputation: 21 Magus2727 Great Standing Member
a change from 30.5 to 29 is not a large or even sudden drop. Winter blends impact it but that should have been used sine November time frame for most gas stations. How do you measure your MPG? did you fill up the exact same station same pump? did you let it auto click off and leave it at that or did you fill more in? if you fill up at a different station, and are a a slightly different incline you can put more or less fuel in. the auto turn off will vary with temperature and with pump. You need to trend it over time. I would not trust a MPG change unless it showed constantly lower for more than 3 repeated fill ups at the same station using the same pump.
Magus2727 is offline
