Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - coolant leak
Thread: coolant leak
Old 01-02-2013, 01:13 PM   #6
Hempster
Hempster's Avatar
Fan#: 29310
What I Drive: 2014 Tuxedo Black Focus ST3
Points 739, Level 14
Points: 739, Level: 14 Points: 739, Level: 14 Points: 739, Level: 14
Level Up 39% Completed
FF Reputation: 3 Hempster Good Standing Member
I suggest you pull the housing and inspect the main ring that seals the housing to the block and make sure there is no oil migrating down the block. Oil swells the rubber and will eventually break the housing. I would also suggest changing the sensor o-ring, on top, to viton while you are at it. I would get about two years before I would get a leak with the oem rubber o-rings, but it's been over 3 since I replaced them with the viton type.
It's also a great opertunity to do a flush.
good luck....
Tuxedo Black 2014 Focus ST3
CD Silver 02 SVTF, #1336 - R.I.P.
"Brace for the G's, and fast heel-toe work!"- Hunter S. Thompson
Hempster is offline
