Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Ran out of gas added gas and won't start
Old 01-02-2013, 06:09 AM   #3
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 32,470, Level 100
Points: 32,470, Level: 100 Points: 32,470, Level: 100 Points: 32,470, Level: 100
Forum Activity 49%
Activity: 49% Activity: 49% Activity: 49%
Eh, hard to tell. Maybe you didn't run out of gas at all. If you hear the fuel pump priming, then the fuel-cutoff switch is ok. Whip out your owner's manual, and check your EFI fuse. Perhaps it is blown. Other than that, you're going to have to take a step back, forget you ran out of fuel, and diagnose the problem as if you'd never known about running out of fuel.
That being said- does the exhaust smell like fuel after you've been cranking the engine? If not, then we're back to checking to see if the injectors are working.
If the exhaust does smell like fuel, then you're getting fuel. The next thing to check would be the coil for damage to the coil plug-in connector (pull on wires individually), resistance test on the primary output, and ignition fuses. If you determine that you have no problem with the coil, or you've checked for spark output by using a spark plug tester- then move on to testing for compression. BTW, I do not recommend testing spark plugs by resting them against the block and having someone crank the engine. There are inexpensive tools that you can purchase or rent which will test if there is spark in a plug wire. If you're going to rent a tool, just rent a timing light, hook it up under the hood and hold the trigger down.
If you have spark and fuel, then you don't have compression or it would be running. Remove the timing belt inspection cover, and see if the timing belt is broken. This wouldn't be the first time an "evil coincidence" like this happened.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
