Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - my very slow forced induction build!
Old 01-01-2013, 11:35 PM   #1
700whpfocus
Fan#: 40899
What I Drive: 2000 zx3 twillight blue focus
Points 6,438, Level 52
Points: 6,438, Level: 52 Points: 6,438, Level: 52 Points: 6,438, Level: 52
Level Up 44% Completed
FF Reputation: 2 700whpfocus Good Standing Member
Buy-Sell-Trade Rating: (11)
Smile my very slow forced induction build!
1)JE FSR Pistons (New Style piston; 9.0:1 85.5mm bore) , The JE Pistons have the upgraded wrist Pins (thicker wall pins to handle high boost / loads), 2)Crower I-Beam Rods, 3)Pro-Gram Billet Main Caps , 4)ARP Main Studs, 5)Clevite H-Series Rod & Main Bearings, 6) Ford Crank that has been rebalanced, 7)new freeze plugs, 8)deck has been resurfaced, the oil filter plug has been modified so the main oil galley is not blocked and the engine gets full oil flow.the oil clearances are on the tighter side of the spec sheet to allow for better oil pressure. ..$1800
9) FORD RACING INTAKE MANIFOLD WITH 70MM TB...$450
10)FORD RACING HEAD WITH UPGRADED VALVE SPRINGS, INTAKE AND EXHAUST VALVES (1MM). EXTRA WORK ON HEAD.MORE THAN "FR"
11)MC NEWS TURBO CAMS....$150
12) FOCUS CENTRAL CAM GEARS..$75
13) ARP fLYWHEEL BOLTS...$25
14) ARP MAIN AND HEAD STUDS...$50.....each set
15)FORD RACING OIL PUMP.. $50 .I WISH IT WAS THE CFM BILLET.OH WELL...brand new
16)SIEMENS 80 LB FUEL INJECTORS....$195 17)NEW TIMING BELT& TENSINORS SET..$50
18) BRAND NEW WATER PUMP...$50
19) CUSTOM RADIATOR.....$100
20)OBX FUEL RAIL.AEROMOTIVE BOOST DEPENDENT FUEL PRESSURE....$215 REGULATOR.......HOPING TO GO FUEL RETURN.LOOKING TO GET THE DEATSCHWERKS FUEL PUMP DW300.....320LPH21) FORD GT FUEL PUMP IN 2003 FORD FOCUS BASKET- $100
22)SYNAPSE 50MM WASTEGATE...$125
23)SYNAPSE BOV ......$100
24)GARRETT GT3582R DUAL BALL BEARING......GOT IT FOR A STEAL "$549"....BRAND NEW
25) HUGE INTERCOOLER 3 INCH INTAKE /OUTPUT....FREE
26) BLASST STAGE 2 TURBO KIT...WILL BE MODIFIED
700whpfocus is offline
