Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2001 Station wagon rear latch not working?
Old 01-01-2013, 07:12 PM   #4
amc49
Fan#: 96610
Points 6,538, Level 52
Points: 6,538, Level: 52 Points: 6,538, Level: 52 Points: 6,538, Level: 52
Level Up 94% Completed
Forum Activity 80%
Activity: 80% Activity: 80% Activity: 80%
Yep, you can move everything on wagon too. The pin that mounts on middle of bumper area has a plastic cover that wears off in use when door fit gets looser. Often that lets latch not work since assembly not as dimensionally tight as before. Moving bumper part slightly around can often pick the needed distancing back up to work correctly. You want it loose enough so that latch catches fully to double latch, but tight enough so that door is pulled into seals, if not, door then begins to rattle. The seal not only seals out water and exhaust stream but shock absorbs the door.
amc49 is offline
