Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Cigar lighter and reverse lights not working...help please
Old 01-01-2013, 07:33 PM   #5
elsolo
elsolo's Avatar
Fan#: 96835
What I Drive: 2007 white ZX3
Points 2,941, Level 33
Points: 2,941, Level: 33 Points: 2,941, Level: 33 Points: 2,941, Level: 33
Level Up 28% Completed
Level up: 28% Level up: 28% Level up: 28%
Forum Activity 7%
FF Reputation: 18 elsolo Great Standing Member
The outlet is very simple, just get your voltmeter or test light and check for voltage on the wires that supply the outlet.
The black wire you Tee'd into is just a ground wire.
Test with a test light between the colored wire and another ground, to see if that black wire is no longer making a good connection to ground.
The colored wire is on fuse #47 a 20 amp, behind dash, and that is after a 40 amp fuse #7 under the hood
I have no idea what a "PIE aux" is, or why you would have Tee'd into the ground wire on a 20 amp circuit for it.
The cigar lighter is the simplest circuit on a car. You have a fused hot lead, and a ground wire.
elsolo is offline
