Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Feedback From Those WIth Dry Nitrous Kits
Old 12-31-2012, 11:55 AM   #12
focusmaniaczx3
I need BOOOOST!!!!!!
focusmaniaczx3's Avatar
Fan#: 55157
What I Drive: zx3 turbo, kia soul, 71 chevy c/10
Points 16,619, Level 82
Points: 16,619, Level: 82 Points: 16,619, Level: 82 Points: 16,619, Level: 82
Level Up 54% Completed
Forum Activity 7%
FF Reputation: 35 focusmaniaczx3 Great Standing Member
Buy-Sell-Trade Rating: (14)
dude just let the guy go. we have tried to tell him and he wont listen so just let him pop his engine. he doesnt understand that combination of ECU, injectors, and maf for the zetec dont support dry kits very well. the only way you are going to get enough fuel to safely run a dry kit will be to run bigger injectors and have a TUNE that pumps enough fuel to keep up with the nitrous. you will have to have a different tune for every different size shot you want to run and the car will run like shit when you are not on the bottle unless you change to a N/A non-nitrous tune. now that isnt all that different from how you would have to do it with a wet kit because you have to or at least you SHOULD change the tune for every different size shot. i never got tuned for nitrous and i probably made several hundred passes on a wet nitrous kit between 35 shot and 125 shot. never puddled the intake and never popped my motor because im not a moron. but here is the difference. with a wet kit you can drive the car around with the nitrous tune while you are off the bottle and it still runs very close to like normal. and with a wet kit you have less of a chance of leaning out and burning your engine. if you have an intermittent injector failure, which happens quite a bit with the zetec, then you will pop your engine. it only has to last for a few seconds to do serious engine damage. im not sure if anyone has figured out why, i know i haven't got a clue and ive tried to figure it out several times. sometimes the zetec will just stop firing an injector for a few seconds or minutes. sometimes if fails all together and sometimes it simply cuts it down by a percentage. i think it has something to do with the MAF and/or ECU because this problem stops with EXTENSIVE tuning and with a diablo MAFia. now with a wet kit you are still getting the additional fuel even if an injector stops working so you have longer to notice before you are in danger of popping the motor and if you play it smart and always run a bigger pill on the fuel side than the nitrous side and just run the kit rich then you dont have to worry at all. there is also the fact that a wet kit is EASIER to install on the zetec IMO. why the hell would you go to the trouble of tweaking in the wiring and risking messing up injectors and computer on your car with a venom kit when you can simply take 3 minutes to use a $15 fuel rail adapter from CFM and the provided hose to run additional fuel? i just cant wrap my head around why you would possibly want to run a dry kit when we are strait up telling you that it is SAFER and EASIER to run a wet kit. and it isnt like it costs that much more. how much were you planning to spend on that venom kit? hell ill sell you my old zex wet kit with a few bells and whistles if you need a nitrous kit that bad. im sorry if i come across as a dick sometimes but i dont like seeing people pointlessly risk blowing their cars up. at least at this point if you are fully informed and you can decide for yourself whether to listen or disregard us. all i ask is that you just dont run a dry kit.
focus-power P&P head $1100
focus-power DIY turbo kit $1495
tom's first time in Vegas? PRICELESS!
Originally Posted by 1turbofocus
I love this big little city HOOTERS !
Back from the dead with very few f***s left to give.
focusmaniaczx3 is offline
