Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Heated Seat Install How-To
Old 12-30-2012, 08:59 PM   #10
dpotter5
Fan#: 105256
What I Drive: 2013 Sterling Gray Metallic SEHatch
Points 73, Level 1
Points: 73, Level: 1 Points: 73, Level: 1 Points: 73, Level: 1
Level Up 46% Completed
FF Reputation: 1 dpotter5 Good Standing Member
Good write up. Just finished this. The spot for the switches worked perfect. The plastic was thin enough that a good, sharp box knife worked fine to cut out the rectangle for my 5 position switches. I used solder for everything and ran the power up under the center console to stuff any extra wires into the void under there. It was an all day project because I was feeling lazy and would do 1 small part then eat and watch Mythbusters on Netflix, but it probably took me around 1 1/2 to 2 hours actual touch time. I did it very tediously and neatly. Heatshrinking everything, tucking everything, etc.
dpotter5 is offline
