Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Problem with flushing the brake system 03 Focus ZX5
Old 12-30-2012, 05:05 PM   #7
Fan#: 94801
What I Drive: 2003 red ZX5
FF Reputation: 1 marsdog Good Standing Member
There was once the fluid level in master cylinder reservoir lower than MIN. s
Maybe this caused the problem?
I don't have ABS so the old school way should work fine.
Originally Posted by ello View Post
How likely is it that you sucked a little air into the system by letting the fluid level in the master cylinder reservoir get too low?
If you have anti-lock brakes, you are supposed to disconnect the battery first. Not sure why or if it matters at all, I have never disconnected the battery to bleed the brakes on anything.
marsdog is offline
