Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Problem with flushing the brake system 03 Focus ZX5
Old 12-30-2012, 12:43 PM   #2
Fan#: 94801
What I Drive: 2003 red ZX5
FF Reputation: 1 marsdog Good Standing Member
Question Problem with flushing the brake system 03 Focus ZX5
I tried to flush the brake system of my 03 Focus ZX5. It has 80k miles and the mechanics warned me to change the brake fluid several times already.
I did the 'press pedal - open bleed screw - close bleed screw - release pedal' approach with a friend helping me and ran almost 1 qt new fluid through to get clear fluid come out of all four wheels.
Then the problem came -- I almost lost the brake force. I figured it must be some air went into the system during the process so I did the bleeding one more time. I didn't see much bubble (if any) come out during the bleeding. The brake pedal is quite firm with engine off but becomes very soft as soon as I turned the engine. Now I have some brake force but it is still softer than before.
Shall I bleed the system one more time? Does driving some miles help move air down the pipe? Is it possible I broke something else?
BTW: with the two-men approach, I don't have to leave some fluid in the waste fluid bottle, put the other end of bleed tube under the fluid and hold the bottle higher than bleed nipple, do I?
marsdog is offline
