Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Trying to locate parasitic drain
Old 12-29-2012, 11:50 PM   #3
my_beautious_ZX3
Fan#: 32386
What I Drive: 2002 charcoal XZ3
Points 1,540, Level 22
Points: 1,540, Level: 22 Points: 1,540, Level: 22 Points: 1,540, Level: 22
Level Up 40% Completed
FF Reputation: 5 my_beautious_ZX3 Good Standing Member
that's normal for the radio - try it again and you'll notice that it displays "1 Hour" when you turn it on with the key off.
A test light is okay for basic live/dead tests, but if you can get your hands on a digital multimeter, that will tell us more. If you search the forum archives, you'll find some typical amp readings that other users have observed on their Focii.
Whether you're using a test light or ammeter, note that the vehicle electronics will reboot and enter a state of high activity for several minutes after they are re-energized. Therefore, ignore the initial tester behavior, and then make your observations after the electronics have settled into their steady-state operation, in the sub-amp range. If you're seeing greater than an amp, then systematically pull fuses in both boxes. Don't turn on any high-load accessories or you'll probably blow the fuse on your multimeter.
"I'm jealous of girls because they get to wear dresses." (Todd Flanders)
my_beautious_ZX3 is offline
