Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Power Steering Pump high pressure fitting
Old 12-29-2012, 11:19 PM   #1
Joelnaf's Avatar
Fan#: 93167
What I Drive: 2003 Silver ZX5 SVT
FF Reputation: 1 Joelnaf Good Standing Member
Hey everyone, so i've just had my motor out of my car because I was doing a ton of work and decided it would be easier outside the car..... anyways I installed the motor and it runs great but I developed a really bad power steering leak. I did not disconnect the power steering fitting (i took the pump off the motor and swung it out of the way to get the motor out). Now that i reinstalled it and the hose in the fitting is loose. The fitting is as tight as I can get it but the hose has wiggle room and letting fluid by. Obviously the hose is not seating on the inside of the pump and as a result it is leaking very badly.
Bottom line: Power steering high pressure fitting is tight but the hose is not seating causing it to leak.
I was doing research on it and some guys in England say that it needs a modified hose and pump???? I just don't want to have to replace the whole power steering hose.
Has anyone else experienced this problem or do I just need a new hose?
Thanks everyone!!
Joelnaf is offline
