Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - The TICK build thread
Old 12-29-2012, 05:13 PM   #38
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 14,460, Level 78
Points: 14,460, Level: 78 Points: 14,460, Level: 78 Points: 14,460, Level: 78
Level Up 3% Completed
Level up: 3% Level up: 3% Level up: 3%
Forum Activity 99%
FF Reputation: 21 Magus2727 Great Standing Member
Well it has been a while due to not having time or money. But have gotten some work done over the last few months. Removed the rear drums so I can convert over to rear SVT disc brakes. Will install with Power Slot and Hawk HPS pads (same as what I have up front) and will be using Stainless Steel lines.
Right now I am waiting to find a kit, or go to the local junk yard, their is a lack of Foci and lack of any with rear disc brakes in my area.
Also worked on the EGR bung for the SVT header.
I have the hole drilled in the header to be just the right size and ground down and cut at an angle the adapter. I used just a small tack of super glue to keep it where I want it so it is not moving on me when I do the first weld tack. The adapter only protrudes into the airflow by a millimeter or two. A complete contrast to what was done before (above in post #16)
Will be using a MIG welder in the next week or two to weld it in place. Will also be swinging by an exhaust shop to pick up 2-3" of some excess exhaust grade stainless steel so I can bend to patch the other large hole in my header. Plan on welding this patch and the Oil adapter / bung on the oil pan and then I will be done with welding.
Magus2727 is offline
