Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - A better understanding of the 2012 ATX
Old 12-28-2012, 11:14 PM   #22
suss6052
suss6052's Avatar
Fan#: 95752
Points 12,317, Level 72
Points: 12,317, Level: 72 Points: 12,317, Level: 72 Points: 12,317, Level: 72
Level Up 67% Completed
Level up: 67% Level up: 67% Level up: 67%
Forum Activity 9%
Buy-Sell-Trade Rating: (3)
Originally Posted by 84Camaro_L69 View Post
I've noticed that while the weather is cold the clutches engage like a manual tranny until they get warm (I believe it's called clutch chatter). The "clutch chatter" or whatever it's called, happens on warm days when you start from 0mph with a moderate amount of gas. If driven like a granny or a lead foot the clutch transition from 0 to whatever, and from 1st gear to whatever gear is smooth (1st to 2nd or 1st to 3rd or 4th).
Periodically I change from auto mode to manual mode just to see what gear it's in. At 30mph it's in 4th gear and at 35mph it will change to 5th or will let you change to 5th gear. Depending on the speeds traveled while switch gears, it will downshift automatically.
Unless you have the later 12B37 programming or the 2013 programming you can get into 6th gear at 35 mph either in drive or in manual shift mode.
5th gear at 35 is over 1500 rpm, 6th is only around 1300 rpm. 40 mph in 6th is right around 1500 rpm.
suss6052 is offline
