Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Replacing stock cd/radio in 2000 Focus.
Old 12-27-2012, 06:56 PM   #14
Kipp
FocusFest Event Team
Kipp's Avatar
Fan#: 31300
Points 4,856, Level 44
Level Up 53% Completed
there is only an amp if you have the factory sub. the speakers are not amped. You'll need the three parts below for the install (dash kit, harness, antenna adapter).
http://metraonline.com/part/70-1770
http://metraonline.com/part/99-5200
http://metraonline.com/part/40-VW10
If you do have the factory sub then you will also need to get a male rca end to hook it up. there is a third plug that has the signal and turn-on wires in it that you connect to. there isn't an adapter made for it so it has to be spliced in to the factory harness.
2010 Volvo C70
2011 Harley FLHTK
Midwest Crew #22
Kipp is offline
