Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2004 SVT performance suggestions
Old 12-27-2012, 04:04 PM   #42
AJ_ST170
AJ_ST170's Avatar
Fan#: 107458
What I Drive: 2004, Imperial Blue, ST170 (ZX3/SVT
FF Reputation: 1 AJ_ST170 Good Standing Member
Post
Okay that makes a Ton of sense, So the SVT-ST170, ZX3 issue is solved.
Thanks ViperThreat
I do plan to Turbo the car but not straight away...I want to squeeze as much power out of this normal aspirated engine as possible
I am planning on stripping the engine and replacing rings and bearing (mains and big ends) so in this process I would like to work the head (gas flow, cams, lightened valves) and any other suggested modz. Then work on the intake, possibly ITBz and cold air induction....
I would like specs on cutting the original cams, modifications to the values, higher compression pistons, engineering of the crank... This is where im looking for advice
If I have offended you, eat a banana, I am sure that will make you fell better...
AJ_ST170 is offline
