Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Wheel hop!
Thread: Wheel hop!
Old 12-27-2012, 02:01 PM   #20
mac.mogul
mac.mogul's Avatar
Fan#: 90409
What I Drive: 2011 Sterling Grey SES Sedan
Points 5,203, Level 46
Points: 5,203, Level: 46 Points: 5,203, Level: 46 Points: 5,203, Level: 46
Level Up 27% Completed
Level up: 27% Level up: 27% Level up: 27%
Forum Activity 12%
Activity: 12% Activity: 12% Activity: 12%
FF Reputation: 20 mac.mogul Great Standing Member
Originally Posted by Brabs_Weather View Post
I have wheel hop and the only thing that cured it in my other FWD car was to eliminate any toe change on acceleration. Buy changing all the stock rubber bushings with better ones. Shocks that do not dampen well will perpetuate the wheel hop but is not the cause. Wheel hop is more your suspension but not 100% but really close.
Suspension bushings are part of your suspension.
Wheel hop is 100% suspension related. You can do lots of things that will trick you into believing you have gotten rid of wheel hop, but only adjusting/tuning suspension components will have any real effect.
Tires with stiff sidewalls will succumb to wheel hop at a lower threshold than tires with a soft sidewall. Wheel hop is still possible, but your tires are now soft enough that you won't see it. The caveat to soft sidewalls is less responsive handling.
You can change to a stiffer motor mount which keeps the engine from bucking around under hard acceleration/deceleration. In a low-powered car you might not experience wheel hop after changing the motor mount, but start adding power or change to racier clutch/flywheel and you could be seeing wheel hop again even worse than before.
Wider tires actually will help to prevent wheel hop because the larger footprint keeps the tire from losing grip when the geometry of the suspension changes. The problem here is that if you're running high power and wide sticky tires on a stock suspension, you're going to break something.
The only way to get rid of wheel hop and prevent breakage is to adjust/tune your suspension components properly. Under hard acceleration, wheels on independent axles will pull towards each other so a slight amount of toe-out is beneficial.
(A RWD solid axle car like a Mustang will need aftermarket LCAs to get rid of wheel hop [driver mod helps, too])
2011 SES 5spd #006 >> SR #213
What other people think of me is none of my business.
mac.mogul is offline
