Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - easiest aftermarket exhaust install what one
Old 12-26-2012, 11:31 PM   #11
Barrow88
Barrow88's Avatar
Fan#: 91009
What I Drive: 10' Black SES, 02' Boosted ZX3
Points 964, Level 16
Points: 964, Level: 16 Points: 964, Level: 16 Points: 964, Level: 16
Level Up 64% Completed
FF Reputation: 4 Barrow88 Good Standing Member
The factory exhaust is not put together like the aftermarket cat-back systems are it is only bolted on at the flex pipe the rest is fully welded and installed before the rear sub-frame is installed at the factory, so therefore the only way to remove it is cut it or drop the rear sub-frame.
You could always get your factory welded where you cut it if you ever want to put it back on. But the FSWerks exhaust is very simple to install I have not seen one post about pieces missing or anything like that. I would say go with the FSWerks.
'10 SES
Build Thread:
ZX3
Build Thread: Already Built... For Now
Barrow88 is offline
