Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - easiest aftermarket exhaust install what one
Old 12-26-2012, 07:38 PM   #4
TMDJ5
Fan#: 107386
What I Drive: 2011 Black Ford Focus SE 2.0
FF Reputation: 1 TMDJ5 Good Standing Member
Originally Posted by Kipp View Post
any of the bolt together systems will work fine (which are most aftermarket systems). if you get something custom made and welded that will take more work. the hard part isn't installing, but removing the stock exhaust. if your bolts are seized (flex to catback) could be a pain, but the bigger issie is you have to cut the back section in front of the rear subframe to remove it. not a bad process if you have the right tools to cut it with.
Is it absolutely necessary to cut it though? I mean, I know a few friends of mine who cut there's, but why can't you just unbolt the whole thing and slide it out?
TMDJ5 is offline
