Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - easiest aftermarket exhaust install what one
Old 12-26-2012, 03:32 PM   #3
Kipp
FocusFest Event Team
Kipp's Avatar
Fan#: 31300
Points 4,856, Level 44
Level Up 53% Completed
any of the bolt together systems will work fine (which are most aftermarket systems). if you get something custom made and welded that will take more work. the hard part isn't installing, but removing the stock exhaust. if your bolts are seized (flex to catback) could be a pain, but the bigger issie is you have to cut the back section in front of the rear subframe to remove it. not a bad process if you have the right tools to cut it with.
2010 Volvo C70
2011 Harley FLHTK
Midwest Crew #22
Kipp is offline
