Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Finally A Focus on TARMACS!
Old 12-26-2012, 03:25 PM   #43
SilentSamurai
SilentSamurai's Avatar
Fan#: 105928
What I Drive: 2015 FOCUS ST3
Points 492, Level 9
Points: 492, Level: 9 Points: 492, Level: 9 Points: 492, Level: 9
Level Up 84% Completed
Level up: 84% Level up: 84% Level up: 84%
FF Reputation: 1 SilentSamurai Good Standing Member
Originally Posted by rambleon84 View Post
I like the wheels and the way the car is sitting both look great, nice setup for sure. I'm not a fan of the wheel color though, just seems too little or how others have said unfinished... Only thing that matters is how you like them and enjoy them...if you ever stop liking them, a color is easy enough to change.
the op is fine with peoples opinions and critiques, wish more people would be less sensitive to opinions from us internet experts
the right attitude for sure
Originally Posted by Macky21 View Post
Did you change the hub size at all when you ordered them? Which hub size did you pick
Hey Macky, First thing I would check is if the ST is the same as our models.
Our SE's are 63.4 HUB which is what my guy ordered. But their site says 63.3 - According to my wheel guy, "I ordered 63.4 WITH Hub rings." Don't forget to order those!!
So if you do go with these, you def want 18x8.5 +40 with 63.4 hub size and hub rings. Rear's could use a spacer, maybe 5mm to 10mm (max) but not by much.
Good luck!
I should also add that if you want to go lower than me (im at the highest setting btw) I would go a smaller tire. The lowest you can go before stretching the tire is 225's. Anything lower requires stretching of the tire which I don't like nor recommend but you can get low.
SilentSamurai is offline
