Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - This is odd
Thread: This is odd
Old 12-26-2012, 10:52 AM   #24
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
Replacement batteries seem to have smaller diameter posts on them than the OEM battery - at least SEARS batteries do. This makes the battery terminal clamps a potential 'lose' fit.
The battery terminal bolt can be fully cranked down and you may still have a loose fit - especially if the terminal/post has been cleaned many times or excessively.
They make a battery post product that fits over the post to enlarge it for a better fit to the OEM terminal clamp. I don't know how well they work/fit but it might be easier than replacing the terminal clamps. It also may just be another point for corrosion to enter a connection - unseen.
Dielectric grease is always good for a battery connection to keep corrosion to a minimum.
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
