Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - how to get this crap off!?
Old 12-25-2012, 04:51 PM   #9
S0C0nFused
S0C0nFused's Avatar
Fan#: 39405
What I Drive: 2007 TorD-Red ZX5 SES
Points 12,348, Level 72
Points: 12,348, Level: 72 Points: 12,348, Level: 72 Points: 12,348, Level: 72
Level Up 75% Completed
FF Reputation: 77 S0C0nFused Excellent Standing Member
Originally Posted by mrdivito View Post
its not brake dust/dirt, its seems to be actual rust
Easy check. Will a magnet stick to the rim? Yes = Ferrous (steel). No = Aluminum.
Edit: Add: IF your wheels are steel (severe doubts), then you have more/better options to cleaning them up. I strongly suspect however that there aluminum. Aluminum rust (aluminum oxide) is the same color as aluminum. Hence, the dark areas are not aluminum or aluminum oxide. What it may be however is a stain. Aluminum is SOFT. If someone had used an abrasive prior, removing the clear and scuffing away the aluminum oxide, then as the new oxide is forming, it is available to pick up 'staining' agents. If the aluminum was gouged (micro grooves), then the staining agents can become deeply embedded. Also, are the wheels painted? Is the staining just on the paint? Figure out what the problem really is before deciding on a corrective plan is all I am recommending. Save yourself a ton of work (and grief!).
Steeda SRI w/CAI intake. Trubendz SS 2.5" . FR Susp/Struts. Tune by Tom (FocusPower). Rota Grids. SAP rear spoiler. Custom front air dam, rocker panel bits and Rear valance.
Last of the Hatches #28
S0C0nFused is offline
