Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Dreaded Can't fill gas tank problem
Old 12-25-2012, 01:29 PM   #5
Fan#: 107269
What I Drive: 2005, Silver, ZX5
Points 91, Level 1
Points: 91, Level: 1 Points: 91, Level: 1 Points: 91, Level: 1
Level Up 82% Completed
FF Reputation: 1 NitroMan Good Standing Member
Okay, after searching for several days I found that the rear end is called a rear sub frame. There are 5 bolts on each side that hold the rear sub frame in. I basically put the whole car on jack stands with about 30 inches of clearance. With wheels removed put a hydraulic jack under each rear spring. loosened the 5 bolts on each side and lowered the rear sub frame. I was then able to remove the charcoal canister assembly. As previously diagnosed, the charcoal canister was plugged up.
Recommendation: The EVAP lines have special clips on them and I have not been able to find replacement clips. So use great care in removing the lines and do not break the clips.
After reinstalling everything, I can now pump gas into the vehicle with no issues. Problem solved. Hope this helps others with a similar problem.
NitroMan is offline
