Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Michigan people
Thread: Michigan people
Old 12-24-2012, 11:34 PM   #95297
jwill2489
jwill2489's Avatar
Fan#: 78236
What I Drive: 2003 SVT JRSC w/BBK
Points 3,510, Level 37
Points: 3,510, Level: 37 Points: 3,510, Level: 37 Points: 3,510, Level: 37
Level Up 7% Completed
FF Reputation: 4 jwill2489 Good Standing Member
Originally Posted by sjdwales View Post
me neither drew and thanks going to check tirerack out now.
something is definitely wrong in the back, driving 35mph on local roads i cant keep car straight. may have to buy coilovers early and do everything at once.
coilovers are not your solution. whatever is causing that will still be there with coilovers. if you can only go 35 and not keep it straight, something is SERIOUSLY bent.
you should know that Scott, come on now. shocks and struts are not gonna make the car drive all over the place. If the car is that far out of alignment then you need to look into whats bent/broke/ or even missing.
you even told me you cant go at faster speeds without the car's rear end coming loose.
coilovers/arms/plates will not fix that. fixing whats broke will
jwill2489 is offline
