Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Finally dropped on 10+ offsets
Old 12-23-2012, 07:06 PM   #34
darkstar's Avatar
Fan#: 23957
What I Drive: 2002 liquid grey zx3
FF Reputation: 1 darkstar Good Standing Member
Originally Posted by ST33zn View Post
Good stuff man. I read that you're making camber plates; are you getting camber bolts for the rear? A tad bit of negative camber will give the appearance of less poke, and it actually gives a little more ground clearance. Should look on point once you get the camber specs sorted out.
I might consider camber bolts for the rear but the problem is that my h&r springs are maxed out without height adjuster. If I could make rear little more lower then camber will be necessary.
darkstar is offline
