Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Is it possible to run an aluminum flywheel and stock clutch?
Old 12-23-2012, 09:16 AM   #10
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 23,982, Level 94
Points: 23,982, Level: 94 Points: 23,982, Level: 94 Points: 23,982, Level: 94
Level Up 64% Completed
Forum Activity 96%
Activity: 96% Activity: 96% Activity: 96%
FF Reputation: 79 felixthecat Excellent Standing Member
^^^ That's it right there. Just like a heavier flywheel makes it easier to drive as well. Exedy makes a lightweight steel flywheel that is like 2 lbs heavier than the aluminum ones. I see CFM has 2 AL flywheels- I'm not sure which one I'd get, but then I'm not sure which clutch is best to get. I seem to remember someone having issues with Clutch Masters. I can't recall any problems with Exedy or Spec. CFM has their own clutch kit, but I'm not sure what parts are used in that kit.
It will be a miracle if I make it to FF13 on this clutch, so I have to find out soon.
Throw the Exedy oem replacement on board. Plus add a throw out bearing to that order too.
felixthecat is offline
