Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Finally dropped on 10+ offsets
Old 12-22-2012, 07:53 PM   #15
ST33zn
Fan#: 89376
What I Drive: 2005 silver zx4 ST
FF Reputation: 1 ST33zn Good Standing Member
St33zn
Originally Posted by darkstar View Post
Thanks man
The whole story is that I have been looking for low priced rims and bingo there was only a listing for 4x108 and I did think hard about it and I dropped the ball.
Don't worry I will make focus look better and proper. I am happy with it, that's all I want for now.
They don't look narrow in the rear to me, 7 inch wide on 15 inch rim looks good.
I don't plan do any fender work because there are no rub and it scrapes everywhere at max. Right now its around 3/4 inch of clearance from subframe so I am not going to lower it any more for being daily.
Good stuff man. I read that you're making camber plates; are you getting camber bolts for the rear? A tad bit of negative camber will give the appearance of less poke, and it actually gives a little more ground clearance. Should look on point once you get the camber specs sorted out.
ST33zn is offline
