Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Coolant in #2 spark plug hole of Zetec.
Old 12-22-2012, 10:52 AM   #4
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 32,849, Level 100
Points: 32,849, Level: 100 Points: 32,849, Level: 100 Points: 32,849, Level: 100
Forum Activity 42%
Activity: 42% Activity: 42% Activity: 42%
Try this article's advice, and be careful not to strip it. IIRC, it's an aluminum plug. If it's not, heat might help, but you'd have to be careful not to heat the plug itself- just the aluminum around it. I'm not sure if I'd want to go that far, so that's a last resort IMO. Try the mix mentioned above, and let it soak in. You might want to try some minor acid action as mentioned. When you re-install the plug, I'd use loctite- blue or green- to prevent a future galvanic reaction.
Best lube for Rusty Nuts
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
