Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Lower motor mount
Old 12-21-2012, 08:13 AM   #5
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
What I Drive: 2012 YB SE HB, 2011 Edge SEL
Points 16,187, Level 81
Points: 16,187, Level: 81 Points: 16,187, Level: 81 Points: 16,187, Level: 81
Level Up 68% Completed
FF Reputation: 45 SkyPilot Great Standing Member
Buy-Sell-Trade Rating: (19)
Originally Posted by Focused Warman85 View Post
So it makes it to stiff well I guess it's better than my motor flopping around under the hood.
It sure was stiff, you might like it, I just couldn't take it anymore.
Originally Posted by sgtsmasher View Post
so the lower mount is just for torque right? and the top mounts are for just holding the motor and to keep the car for vibrating apart right?
Typically the lower mount is called the torque mount because when its replaced with a stiffer mount it will get more torque to the ground more effectively than stock. The other mounts when replaced with a stiffer will have the same result of getting power to the ground just not as effective as the lower mount.
All 3 mounts work together. as for the Vibrating apart thing. If ANY of the mount wear out it will vibrate. When the mounts get old its recommended to replace all 3 because if you just replace the problem mount (the passenger mount typically goes first) the other 2 weaker mounts can prematurely wear out the new mount.
ZETEC Crew #26 SR #20 YELLOW BLAZE OWNERS GROUP#4
Moderator Pilot, 12 SE HB ╠╬╝, 2011 Ford Edge SEL AWD
SkyPilot is online now
