Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 HID Thread (Info Only No Arguing)
Old 12-21-2012, 06:59 AM   #316
Bwill9886
Fan#: 93444
What I Drive: 2013 Rallye Red Civic Si
Points 1,721, Level 24
Points: 1,721, Level: 24 Points: 1,721, Level: 24 Points: 1,721, Level: 24
Level Up 21% Completed
Level up: 21% Level up: 21% Level up: 21%
FF Reputation: 2 Bwill9886 Good Standing Member
Buy-Sell-Trade Rating: (6)
Originally Posted by Ox-y-GenIII View Post
See, I have the harness, the HID kit, and I think just one resistor that cane with the harness. I'm so confused on how to set it up I gave up. I have read I need 2 resistors, is that correct? One for each side?
You can make do with one if you have a relay harness that's only using one relay for both lights. Darketernal3 explained the method best.
Originally Posted by Darketernal3 View Post
Not necessarily.
It kinda depends on what kind of relay you have, and if all you care about is functionality.
1) If you have independent relays, where each headlamp signal controls a separate headlight then yes, you'll need an individual resistor for each headlight. The relay I had uses the driver's side lamp signal to activate and the passenger side was left plugged into the resistor and grounded. Both lights would be switched on regardless if the passenger side had a resistor or not.
2) If you did not put a resistor on the passenger side, or the resistor occasionally didn't impede the current; like mine before I redid it. You will get a bulb dip error. The lights will still turn on, but the bulb dip will come on every time you turned on your lights. If that doesn't bug you, you can go without the passenger resistor.
Edit: I bought my relay from retro-solutions, the original link provided.
So you would only use the resistor on the passenger side, connected like in the retro-solutions diagram. The relay harness on the driver's side that would connect to the resistor in the diagram instead connects to the factory bulb harness. The rest of the connections are pretty straight forward from there.
Make sense? I'm personally running individual relays for each headlight so mine is setup exactly like in the diagram. It seems like this method has worked for a few people, but I have not tried it.
Bwill9886 is offline
