Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Does your vent selector stick? Have you broken the cables? Read on,
Old 12-21-2012, 06:13 AM   #3
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 32,648, Level 100
Points: 32,648, Level: 100 Points: 32,648, Level: 100 Points: 32,648, Level: 100
Forum Activity 41%
Activity: 41% Activity: 41% Activity: 41%
05-07 have no filter- on purpose. An earlier model Foci filter caddy can be substituted in place of the metal mesh screen if you can successfully remove the foam glue holding the screen in place. Something else will have to be used to seal up the filter caddy. Something like automotive window adhesive will work. Adhesive foam rubber should work if it's heavier duty type that will withstand high and low temps. The good thing is that the factory part bolts on the same way so there's no problem with having to drill holes.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
