Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Manual Gear lever problems
Old 12-20-2012, 11:32 AM   #3
gtferrari
gtferrari's Avatar
Fan#: 88110
Location: Grand Rapids/Big Rapids/Bangor/South Haven, MI
What I Drive: 2008 Vista Blue SES Coupe
Points 1,054, Level 17
Points: 1,054, Level: 17 Points: 1,054, Level: 17 Points: 1,054, Level: 17
Level Up 54% Completed
FF Reputation: 4 gtferrari Good Standing Member
yes unscrew your shifter then lift the boot up at the end closest to you the front will then slide out. pull it off the shifter. there are to points where the cables attach to the shifter. you will see coil springs with the ends sandwiching the one on the right this is the centering spring. as you move the shifter you are lifting or pushing on the spring. it sounds like one of the fingers on the spring has broken or that the entire spring has detached from the shifter mechanism.
2008 Vista Blue SES Coupe 5spd FRPP Zx3B Suspension
5000K D2S Retrofit
130,000+ miles and still on factory brakes and clutch!
Rep Points dont add themselves
gtferrari is offline
