Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Alternator installation
Old 12-20-2012, 04:19 AM   #18
amc49
Fan#: 96610
Points 6,810, Level 54
Points: 6,810, Level: 54 Points: 6,810, Level: 54 Points: 6,810, Level: 54
Level Up 30% Completed
Forum Activity 100%
I don't do video...............self-explanatory if you simply look at the alt. The threads for attaching bolts to go through are in steel inserts that are pressed into the aluminum bosses, in tight but move sideways with enough force. Tightening the bolt pulls them up tight to pinch the bracket hard, when taking alt off you must push them back out so the bosses loosen up to let alt simply fall out. I use visegrips to press them sideways. Or thread bolt partially into hole and then tap on bolt head itself.
amc49 is offline
