Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2010 focus door problems
Old 12-19-2012, 12:55 PM   #2
gtferrari
gtferrari's Avatar
Fan#: 88110
Location: Grand Rapids/Big Rapids/Bangor/South Haven, MI
What I Drive: 2008 Vista Blue SES Coupe
Points 1,054, Level 17
Points: 1,054, Level: 17 Points: 1,054, Level: 17 Points: 1,054, Level: 17
Level Up 54% Completed
FF Reputation: 4 gtferrari Good Standing Member
i would get a wiring diagram and a dvom (digital volt ohm meter)
use the diagram to figure out what wires to test for. look for the ground wire. in ohm mode connect one lead to the ground and the other to the neg terminal on the bat. should read 0.0
now set it to vol= not vol~ find the positive wire and put a lead on that then leave the other on the neg term of the batt. press the button. you should see 12.6 volts
most likely you are looking for a bad ground or resistance in the wires or connections
2008 Vista Blue SES Coupe 5spd FRPP Zx3B Suspension
5000K D2S Retrofit
130,000+ miles and still on factory brakes and clutch!
Rep Points dont add themselves
gtferrari is offline
