Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - koke's turbo kit build
Old 12-18-2012, 11:43 PM   #82
koke'sfocus
koke'sfocus's Avatar
Fan#: 69779
What I Drive: 05 silver st
Points 4,267, Level 41
Points: 4,267, Level: 41 Points: 4,267, Level: 41 Points: 4,267, Level: 41
Level Up 59% Completed
Level up: 59% Level up: 59% Level up: 59%
FF Reputation: 1 koke'sfocus Good Standing Member
Buy-Sell-Trade Rating: (6)
Originally Posted by old1030 View Post
If you suspect your head gasket is bad the easiest way to tell is to pull the plugs out and check for oil.
Ok thanks I check that out tomorrow
cossie im, cfm 67mm tb, 3" dp, 3" exhaust and custom turbo kit, holset hx35 turbo on 13psi, exedy stage 2 clutch and flywheel
Stock long block 353whp 280lbtq, 13psi
team duratec #94
D23 crew #9.
koke'sfocus is offline
