Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - worn brakes, need upgrade
Old 12-18-2012, 09:16 PM   #2
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 24,774, Level 95
Points: 24,774, Level: 95 Points: 24,774, Level: 95 Points: 24,774, Level: 95
Level Up 43% Completed
Forum Activity 100%
FF Reputation: 80 felixthecat Excellent Standing Member
A great bang for the buck would be the SVT front brakes. 300mm rotors & bigger calipers, that bolt right on. You will need 16'' wheels.Some 15'' might work. Your stock brake lines will work, but I install new ones or upgrade to Stainless steel lines. Your cheapest route for the rear is to keep the drums & get new shoes & turn the drums or replace them w/ new ones. Yes you can convert over to disc. The '05-'07 ST's have 10'' disc which are more readiy available, then the svt's 11'' ones. The stock master cylinder will work great. Hit up the B&S section. There are a few sticky's on this subject at the top of this section.
felixthecat is offline
