Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How-to.....Make the rear seats livable for your passengers.
Old 12-17-2012, 12:52 PM   #56
gtferrari
gtferrari's Avatar
Fan#: 88110
Location: Grand Rapids/Big Rapids/Bangor/South Haven, MI
What I Drive: 2008 Vista Blue SES Coupe
Points 1,054, Level 17
Points: 1,054, Level: 17 Points: 1,054, Level: 17 Points: 1,054, Level: 17
Level Up 54% Completed
FF Reputation: 4 gtferrari Good Standing Member
well here are some shots of the interior of a 08+ coupe. sorry sedan folks your rides will be a little bit more difficult because of the window regulators.
to remove the panel first begin by separating the panels. there are some plastic clips that lock the lower to the upper at the seat belt.
[IMG] 2012-12-16_15-18-31_41 by gtferrari, on Flickr[/IMG]
then again at the rear seat belt. there are three there and are a little more difficult to release. the rear trim piece is separate from the c pillar cover and if you undo it from there you will have an even harder time of reinstalling it.
[IMG] 2012-12-16_15-17-38_107 by gtferrari, on Flickr[/IMG]
now at the bottom of the panel near the door you will need to lift the focus name plate a little and sneak the panel from under it.
[IMG] 2012-12-16_15-18-07_658 by gtferrari, on Flickr[/IMG]
now remove the seat bottom by sliding the two locking catches toward the drivers side. the seat simply lifts out.
using some persuasion and patience begin to pop the panel off of the car. no tools necessary. you will find it easier to raise and lower the seat back as necessary. mind you once the panel clips are free the panel will not lift out easily. there are two foam blocks that are glued to the panel that fill the void in the body. gently reach behind the panel and push them down as you pull the panel out.
[IMG] 2012-12-16_15-10-46_185 by gtferrari, on Flickr[/IMG]
the body shop had already damaged this panel by snaping off the smallest block and were nice enough to throw it out for me instead of reattaching it with glue or screws. (i had to do this on the other panel)
now that everything is out of the way you can install your acoustic tiles/blankets/foam/whathaveyou into the void. mindful that the foam on the panel will have to fit back.
it was now that i noticed a void that extends back into the trunk that runs just beneath the window and presumably goes into the c pillar. i stuffed a small blanket into this area as there was no way to measure and cut/fit the carpet to fit it. (the carpet has been affixed to the body panel (with arrow) and you just make out the green blanket.
[IMG] 2012-12-16_15-10-52_693 by gtferrari, on Flickr[/IMG]
once you are satisfied with your work you can begin reassembly following the steps in reverse.
one box of carpet squares (ruffly 22 sq ft) was enough to do most of the trunk and for the little bit of interior (pictured). now i have the audiophile system with sub so i wasnt able to place carpet on the drivers side of the trunk.
2008 Vista Blue SES Coupe 5spd FRPP Zx3B Suspension
5000K D2S Retrofit
130,000+ miles and still on factory brakes and clutch!
Rep Points dont add themselves
gtferrari is offline
