Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - LCQ-1 install
Thread: LCQ-1 install
Old 12-17-2012, 08:06 AM   #3
ArcticGabe
Fan#: 86046
What I Drive: 2013 SE Hatch MTX
Points 65, Level 1
Points: 65, Level: 1 Points: 65, Level: 1 Points: 65, Level: 1
Level Up 30% Completed
FF Reputation: 1 ArcticGabe Good Standing Member
I'm thinking of doing the same thing to mine. Where are you mounting the LCQ-1? I'd like to mount it up front, close to the head unit so I do not have to run speaker wires up and down the car.
I have not heard that the rears are rolled off below 45Hz, but I see nothing wrong with using channel 2 for the fronts. You may want to test to make sure the auto-sense turn on works from channel 2 inputs, else you may need to run a separate turn on trigger. I believe the factory trigger is the Yellow-Violet from the radio unit (at least it is on the Sony systems).
ArcticGabe is offline
