Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Revs staying high before idling correctly.
Old 12-17-2012, 07:53 AM   #12
steveplatt28
Fan#: 107192
What I Drive: 2001 Dark Blue 1.6cl focus
FF Reputation: 1 steveplatt28 Good Standing Member
put car into local diagnostics centre which came up with no fault codes. upon further investigation they found that no's 1 and 4 spark plugs were arching. all 4 replaced and all was well.......... until this morning when started up having not used it all weekend back to bad running although it now idles perfectly. the problem seems to be when its under load, if you feather the throttle its fine, as soon as you give it too much throttle it hesitates and judders. also engine light was flashing and then gone out again!! dont cars do your head in?
would agree with your unmetered air solution so if problem re-accures with idling that will be my first port of call.
Many thanks steve
steveplatt28 is offline
