Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - MK1 rear disk brake kit recommendations ?
Old 12-16-2012, 10:59 PM   #3
angelwolf71885
angelwolf71885's Avatar
Fan#: 107341
What I Drive: 2003 FORD Focus ZTS SDN RED
Points 164, Level 3
Points: 164, Level: 3 Points: 164, Level: 3 Points: 164, Level: 3
Level Up 28% Completed
Level up: 28% Level up: 28% Level up: 28%
FF Reputation: 1 angelwolf71885 Good Standing Member
well what i really want is the ABS system and as i understand it
the ABS system works far better with disk then drum
im not even sure if you could get ABS from the factory without 4 weel disc
also i feel cheated by ford in that the ZTS is the best edition of the focus you can get and it didnt even come with 4 weel disc let alone ABS
SVT excluded because it was a special order edition
sounds like ill go junk yard hunting then
if i find SVT brakes will i NEED the larger rims?
or can i keep the stock 16 weels of the ZTS?
thanks alot for the reply
angelwolf71885 is offline
