I do actually have gold vinyl ready to go, should have mentioned that. White might be the next color down the road, it's not a bad color, I just want to have a bit of a metallic flake on the color. And Goldmember would approve I see. [thumb]
the gold isn't too bad on the blue! I think if you made your fog bezals gold it would fill it in the picture nicely
also if you "golded out" your side view mirrors! hehehe
Hey I developed a really easy way to get the bezals out! I will explain to you how I do it...
1. Remove headlight.
2. reach down under where the headlight was with one hand, and push down and out the 2 clips for the bezal. (first look down there and identify the clips... you should be able to see the chrome on the top and the outer side of the fog assembly. you can feel them too. just use 1 finger, like your thumb, to push down on it and then use another finger to push it out towards the front of the car. Do that to both of them.) You need strong fingers/hands
3. sit down or kneel in front of the car and you should now be able to get your fingers in between the bezal and the fog light. grab it with both hands and pull straight towards you and away from the car. You need to apply some force in order to pull it out - don't worry - none of the tabs will break. I've done it several times now. I actually had initially cracked a tab trying to use a screwdriver [facepalm] .
4. there is no step four. you're done [woot]
5. putting it back in is super easy. you don't need the headlights off for it either. You just go to the front of the car and snap it in! read the back of the bezal because it will say either LH or RH. the LH is the driver's side. It wouldnt fit at first because I had them switched. [facepalm][facepalm]
Just ask for torx bit/s. You need a T30 size torx. I bought a torx kit with a magnetic screwdriving ratchet thingy for $20. Not sure what i'm going to do with the rest of the bits lol.
Yeah blue wasn't really an option just seeing whats out there haha and I like white, but they would get dirty asap and are kind of "too out there" I like the black and grey as well, just not sure which one...
If it was me, I'd go with the grey. It look really good with the Performance Blue. I wouldn't go black because black wheels don't really show any depth. I think the white does look good. But that's just my .02, go with whatever you feel looks the best. They all look good, just pick something you are going to want to see every day.
Go with the dark gray, it was my favorite wheel color and gave it a stealthier look, black makes it look like you have steelies if you lighting is bad.
I may just go with black. I really want team dynamics but there a little more pricey... I want 18's but I don't want to buy more tires and I hate how my car rides now with the low profiles... Especially living on a dirt road...
Once I get the money, I'm gonna be getting new wheels. I'm going white and have them 18x8.5. I will probably have to stretch tires and run a little camber, but my car will have a pretty good fitment then. I think you should go 18's, mainly for looks. But it's all about what your wants are. If you want better ride quality, get some 17's and run tires with more sidewall. Are you going to lower your car?
That's the problem with ordering after the order bank opened but before they were building the 2014 MY models, the wait can be much longer.
Had you ordered it during the middle of the model year it would normally take 4-8 weeks from order to delivery, so 9-10 weeks or so isn't that bad given they just started building the 2014s on 7/8/13 afaik.
Yeah I was told 6-8 weeks, but thats probably just normal talk that they forgot about the two weeks off and that the car was brand new... Its just a SUPER long wait!
Yeah I may do that. For now its dark grey...but my mind changes quite often lol
Related Threads
Focus Fanatics Forum
5.8M posts
189.1K members
Since 2003
