Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 HID Thread (Info Only No Arguing)
Old 12-16-2012, 11:44 AM   #309
Fraychild
Fraychild's Avatar
Fan#: 37309
What I Drive: 2012 Ford Focus SE
Points 62, Level 1
Points: 62, Level: 1 Points: 62, Level: 1 Points: 62, Level: 1
Level Up 24% Completed
FF Reputation: 2 Fraychild Good Standing Member
Originally Posted by Slammed_2.0 View Post
Also, with my buddies 2012 Focus SE, when I installed his HID kit without resistors (55w Kit) I didn't use any load resistors but still used a relay harness. No dipped bulb or any failures.
I'm not sure how this is even true - I installed my 35W HID with Relay + Resistors and it worked perfectly fine - both while car is turned on, idling and driving.
I also installed a 55W HID kit with just the relay, and though it'll turn on with the car shut-off, it doesn't work when it idles or drives.
Bottom line, you need the 2 Resistors and the relay harness whether you're running a 35W or 55W HID kit.
My 2 cents? Do it right the first time and save yourself the hassle.
2012 Candy Red SE Manual... I smell serious trouble.
Fraychild is offline
