Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Easiest way to install push button start?
Old 12-16-2012, 01:05 AM   #10
TheDude
Fan#: 107335
What I Drive: 2002, black zx3
FF Reputation: 1 TheDude Good Standing Member
You could do what I did. Take the ignition switch completely out canceling out the use of the key you have to remove it so your steering wheel doesn't lock up. Run all your accessories to a toggle switch and run the ignition wire off a push button or straight from the starter solenoid to the push button. This way you can turn all your accessories on if you need just that. You can not wire them all together including the ignition cable because it will constantly try to start your car so you will be grinding out your starter. It is a pretty simple process you just have to find out what wires do what and run your new power and ground for the toggle and your all set.
TheDude is offline
