Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Oil Leak: Dealer said Ford stated This is NORMAL
Old 12-15-2012, 04:19 PM   #90
Kabigon
Fan#: 88299
What I Drive: 2012 sterling gray Titanium
Points 5,736, Level 48
Points: 5,736, Level: 48 Points: 5,736, Level: 48 Points: 5,736, Level: 48
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
Forum Activity 5%
FF Reputation: 11 Kabigon Great Standing Member
Originally Posted by Silver 2012 Focus View Post
After 3+ days in the shop to fix the leak between the engine and the transmission, I have the car back. The paperwork does not specify that TSB 11-12-13 was performed but the text lists the steps that are in TSB 11-12-13 and the parts list is the same with one exception - the cluth assembly is BV6Z-7B546-B instead of BV6Z-7B546-A. I'm assuming since the TSB came out, the part was revised (hopefully for the better).
On the drive after picking the car up, I noticed the follwing:
1) The clutch was very grabby in the parking lot at low speed.
2) The transmission made no noise during any shift.
3) The shifts were a little harsh to start but by the end of the drive they had calmed down.
4) On my way home from work where I travel up and down different hills, the car did not seem to have difficulty with them - it seemed to be in the apprporiate gear and the transmission did not cause a shudder as it would have before the replacement.
Hopefully this is my last post on this subject. Only time will tell.
The adaptive learning should improve the clutch engagement after some amount of mixed driving.
Kabigon is offline
