Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Custom rear spring perches
Old 12-15-2012, 12:51 PM   #3
2000blackzx3
2000blackzx3's Avatar
Fan#: 9744
What I Drive: 2002 SVT Focus
Points 2,890, Level 32
Points: 2,890, Level: 32 Points: 2,890, Level: 32 Points: 2,890, Level: 32
Level Up 94% Completed
FF Reputation: 21 2000blackzx3 Great Standing Member
Thanks for the pics, from what I can see you use the control arm hole as centering and its top edge as the vertical contact surface. Are the 3 screws for tightening the perch to the arm with the black washer from underneath? (I just want to eliminate any possible clunking if it's not tightened, stock springs clunk if rubber is removed from the bottom coil)
Any input on existing spring diameters and heights commonly available to test different spring rates? I guess I will use my FK perch at top and fit a machined perch for the same I.D. at the bottom. That KW bottom perch is 3 parts right? Male threaded top part with hexagonal hole accessible from underneath, female threaded bottom part and washer to tighten the part from underneath? Am I right on this?
Canadian ASN FIA National Autoslalom Champion, 2012
Other championships won :
2013 Overall & SP, CADL / 2013 SP, Quebec Championship / 2012 ST & Overall, CADL / 2012 ST, Club Delta Quebec / 2011 Rookie of the Year, CADL
2000blackzx3 is offline
