Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2001 zx3 wont start
Old 12-14-2012, 11:12 PM   #14
H8VTEC
Fan#: 107041
What I Drive: 2001 white ZX3
FF Reputation: 1 H8VTEC Good Standing Member
Originally Posted by sailor View Post
To simplify from the description & diagram, the two wires from the "Driver module" under the rear seat to the fuel pump - one power, one variable ground - either not functional to the pump is ONE failure mode.
The other failure mode is a bad fuel pump - wiring fault internally, or mechanically frozen.
So - If you go by the color codes & where the wires actually go, you can test for a continuous circuit right from the plug to the driver module under the rear seat. No continuity (ohm meter), either the wiring is damaged or the fuel pump is "fried".
If you have continuity, momentary application of 12v. power to those wires & the pump should run, if it doesn't it's "locked up" aka "frozen". and No - if it's locked up it won't work, so it won't pump anything...
luck!
Ok, so the pump being bad is out of the question then. I hear it come on and I'm getting 40PSI when the key is in the ON position.
H8VTEC is offline
