Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2001 zx3 wont start
Old 12-14-2012, 10:52 PM   #13
sailor
Old Phart
sailor's Avatar
Fan#: 57268
Points 31,272, Level 100
Points: 31,272, Level: 100 Points: 31,272, Level: 100 Points: 31,272, Level: 100
Forum Activity 100%
FF Reputation: 133 sailor Excellent Standing Member sailor Excellent Standing Member
To simplify from the description & diagram, the two wires from the "Driver module" under the rear seat to the fuel pump - one power, one variable ground - either not functional to the pump is ONE failure mode.
The other failure mode is a bad fuel pump - wiring fault internally, or mechanically frozen.
So - If you go by the color codes & where the wires actually go, you can test for a continuous circuit right from the plug to the driver module under the rear seat. No continuity (ohm meter), either the wiring is damaged or the fuel pump is "fried".
If you have continuity, momentary application of 12v. power to those wires & the pump should run, if it doesn't it's "locked up" aka "frozen". and No - if it's locked up it won't work, so it won't pump anything...
luck!
sailor is offline
