Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - turn off lights auto when turn off car
Old 12-12-2012, 04:58 PM   #16
suss6052
suss6052's Avatar
Fan#: 95752
Points 12,223, Level 72
Level Up 44% Completed
Forum Activity 3%
Buy-Sell-Trade Rating: (3)
Originally Posted by yanivdan98 View Post
thanks you, i got the manual , however i i didnt understand you how can i set the home safe function that will turn off light after turn off my car?
can someone exaplain it for me?
I have explained it as plainly as I can in my previous post.
Step one: Turn the car off.
Step two: pull the turn signal/ dipped beam switch towards you (this should be on the left side of the steering wheel if its laid out like the lhd cars) until you hear a chime.
This enables the pre-programmed delay to leave the head lamps on for 3 minutes with the door open or 30 seconds after the doors are closed. This is to allow you to have an illuminated path to your home.
If you want to disable it I believe the proceedure outlines pulling the stalk forward again or turning the ignition on and off.
This will only keep the lights on for a set period after turning the car off, this won't turn them back on if it is not already dark when you turn the car on.
suss6052 is offline
