Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Wheels and Tires for 2013 Focus Sedan
Old 12-12-2012, 03:07 PM   #6
thenorm
thenorm's Avatar
Fan#: 14947
What I Drive: '04 ZX3, '14 Mustang GT
Points 7,616, Level 58
Points: 7,616, Level: 58 Points: 7,616, Level: 58 Points: 7,616, Level: 58
Level Up 33% Completed
Level up: 33% Level up: 33% Level up: 33%
Forum Activity 5%
FF Reputation: 43 thenorm Great Standing Member
Buy-Sell-Trade Rating: (5)
Originally Posted by Nickgt40 View Post
Backspacing is the opposite of offset. It's how far the back portion of the wheel is from the cener line on the hub.
not quite...
off set can be positive or negative. measure from the centreline of the wheel.
ie. most FWD car wheels are negative offset, while deep dish wheels for RWD cars can be positive offset.
Backspacing is total distance from the hub face of the wheel to the lip of the wheel (ie. if you put a straight edge spanning accross the back of the wheel)
The stock size is 215/50/17, right?
If that's the case than a 245/45/17 would be fine as long as you're planning to run a wider wheel to match it. I wouldn't suggest anything narrower than a 8" wheel
i agree a 8" wide wheel is needed.
245/45R17 might be too tall. maybe consider a 40 series. confirm with a online tire size calculator (google it).
Also, the wheel offset is going to need to be perfect, so you dont rub too bad
May 2014 ROTM, June 2015 ROTM
for rally-x: '04 Liquid Grey ZX3
Build Thread:
Sold: '02 Infrared SVT
thenorm is offline
